Many problems with UM on v.5.14
Hi guys,
just found weird things on my current UM..
  1. Total Time Left (expired time) goes blank on first login,
  2. Start Time status always ‘Not Set’,
  3. Till Time automatically set to ‘Unknown’
is anyone experienced the same??
any solution yet?
:frowning:
UM 5.14 is still in alpha stage! I see all types of weird behavior in it. If you must use UM in production environment, better downgrade to ROS4.17.
yes, better downgrade to 4.17… but 4.17 does not run on rb1200 …
:frowning:
yes im facing that trouble to, then downgrade to 4.17 now.
thx folks!!
but there are issues in um v4.xx, it is the multiple login for pppoe+UM… my network forced me to not enable the “One Session per Host”, therefore I need v.5xx to get the multiple login to be disallowed from UM…
more ideas?
:slight_smile:
