I saved customized hotspot html files in the root. I noticed the files vanish after device reboot.
After research, it seems this is a “feature” of mAP.
Is there anyway to disable this feature?
When I put the html files under “flash” folder, the hotspot function does not work. I kept getting error 404 when opening the walled-garden.
