I’ll buy a mAP but is it possible to use the 2Lan Ports as Switch? So i can use the Wifi and the 2ports in an allready existing infrastructure(DHCP…)?
I’ll use the mAP Lan Ports so:
Port1: Cat6 to existing Wifi Router
Port2: Cat6 to Laptop or other Devices
Yes, you’ll be able to do that no problem. Just add the ports to a bridge.
Are that a Hardware or a Software bridging/Switch?
I’ll need to Run the Artnet protocol without Timing issues.
