I often have got an mAP with me. I make it connect to an available WiFi network, and have my devices connected via the two eth ports.
However, i want to get rid of each time entering the ssid/psk. I would like to have a list of SSIS/psk pairs in the mAP and the mAP connect automatically to an available SSID.
(as pc’s and tablets do it) Any suggestions how to do this on a mikrotik ?
Enter the desired wlans in the “connect list” tab and enter you home’s “ssid” and “security profile” in the interface’s appropriate fields to avoid connecting to some unknown wlan.
It’s exactly what I do with mine.
Regards,
Sent from Tapatalk
That tab can be found in the wireless window.
Sent from Tapatalk
Thanks, that got me going.
Looks like it can’t be done on a virtual wlan interface (found that the hard way)
