Map Exports
Just wondering if anybody knows..
Running DUDE 4.3 on MT4.14 all sucessfully..
I wanted to setup maps to export so I could then display them on a web page.. Ive got the png’s being created and I can download them from within files in the dude client, but how would I go about FTPing these as I cannot see them in the files in winbox for example?
Regards
Lee
I would not recommend running that version of the dude on RouterOS at this time.
There are some issues with doing larger backups that can cause the database to be dropped entirely.
If you want to use 4beta3 in production (as I am) I would highly recommend you run it on a windows box where you can backup the data directory daily.
