I have a mAP broken, it does not turn on.
How can i repair it temporarily? Components to test?
thank you
thank you
return to seller for warranty. there are many possibilities what could be wrong, it is not simple to tell you what to repair.
hi Normis,
no easy test possible? i see with tester that no tension pass on RB. i try power-on with PoE but no result. Mensuration error?
Write to support@mikrotik.com, we might be able to provide some test instructions
Thank you Normis.
