Hello. I’m more than a little lost right now.
Here’s the situation. We’re trying to use a mAP lite as a bridge. We want to be able to access it from it’s physical LAN even after it’s bridged. It will be be physically connected to another router which is acting as a switch and an access point (that one is already set up). However, there’s a second problem that we’ve been unable to solve.
We can only access the map lite wirelessly, and it doesn’t provide internet when set up as an access point and physically connected to a switch. It will also randomly crash when we apply certain settings, and not allow us to access it again unless we perform a factory reset. We’ve also tried to fix things by exporting a config file from a working router (a map 2nD) and importing it on the lite. So far, nothing has worked. We’d really appreciate any help with either part of this.
Thank you!
Config printout from the map lite:
# jan/02/1970 00:38:39 by RouterOS 6.42.6
# software id = IGQY-Q6KP
# model = RouterBOARD mAP L-2nD
# serial number = 84900756B09D
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors \
frequency=auto mode=ap-bridge ssid=MikroTik-F7AB13 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=wlan1 name=defconf
set discover-interface-list=discover
add comment=defconf interface=wlan1 list=LAN
add interface=wlan1 list=discover
add interface=wlan1 list=mactel
add interface=wlan1 list=mac-winbox
add address=192.168.88.1/24 comment=defconf interface=wlan1 network=192.168.88.0
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
/system routerboard settings
set silent-boot=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
