I got two mAP Lites in the mail today from a local distributor (Duxtel in Australia) and no matter how I try neither of them will broadcast a wireless network.
They’re happy to connect to ethernet but no matter how long I leave them turned on the wifi light stays off and no ‘mikrotik’ SSID ever appears. I’ve tried following the factory reset procedure and had no joy there either.
I suspect my next step involves trying to reimage them with netinstall but I find it rather odd that neither unit would function at all wireless-wise. They follow the usual startup sequence and blink all the various lights, I even get a LAN light and they pick up an IP, but there’s just never any wireless.
This persists across multiple USB cables and power supplies, and even with PoE power.
Just powered the unit on. They’re only configurable over wifi according to the manual, by default the ethernet should be set up as a WAN interface w/o remote access. (They only have one ethernet port.)
The ethernet interface quite happily picks up an IP from my DHCP server, but won’t allow winbox access (as this is configured as a WAN port).
