mAP Lite POE
I want to power the map lite with a poe. Does anyone know if I can use this https://mikrotik.com/product/RBPOE. I suppose that I would need a converter from micro usb female to dc male too!?!
Thank you!
I just checked with my mAP Lite, and that injector (which also comes with tons of Mikrotik products) works (with the 24V DC adapter that came with it, anyway).
You can’t use the USB port on the mAP Lite for anything other than powering it.
@MartijnVdS I thought that the power adapter was a 5v usb? https://routerboard.com/RBmAPL-2nD
Yours has a 24V DC?
The power adapter that comes with the mAP Lite is 5V micro-USB.
The power adapter that I used to power the mAP Lite with the RBPOE was a 24V DC adapter from another Mikrotik product.
