hello everyone
i trying to power up mAP lite from poe of RB960PGS (hEX PoE)
it works fine if i used all 8 lines of cable
but i need 4 lines - data+power at same lines:
1,2+ and 3,6- data and power
or
1,2- and 3,6+ data and power https://wiki.mikrotik.com/index.php?title=Manual:TOC/MikroTik_POE_in_compatibility_table
if i understood corretly (of course, i can be wrong), 802.3af(mode A?) can be use for it. but it doesn’t work. i try crossover and direct cable with same result (map lite not powered on - i try poe ‘auto on’ mode and ‘forced’ at RB960PGS)
I think the mAP can support power in via pins 1,2,3,6 (Mode A) or 4,5,7,8 (Mode B).
And I think the hEX can only send power out via pins 4,5,7,8 (Mode B).
The description of the hEX PoE says “It can power at/af mode B (4,5+)(7, compatible devices, if 48-57 input voltage is used.” It doesn’t say anything about powering anything via mode A.
thx for reply. yeah. i think same about poe-mode-A in hEX PoE. but i will be glad for reply from mikrotik tech support.
very strange wording. because i use standart 24v power supply from retail package of hEX PoE and poe-mode-B works fine.
what mean author of this words - it is secret for me
i think, it is need to print in decstiption (what mode of 803.2af support), because i buyed hEX PoE special for this case. offensively
