Hello, I am sorry if this is not the right topic, but some time ago I got an mAPlite. Wanted to turn it on yesterday and there was no access point. Then I thought that maybe I have to connect to it directly through the IP (192.168.88.1) and by the way it was directly connected to the PC, map lite ethernet port to the pc ethernet port. But that wouldn’t work too. Then I thought maybe I could update RouterOS with netInstall. So I did everything as in the tutorial, while powering on I held down the button, wait that it goes through the CAP and WLN (“wifi” simbol) led cycle, then wait that the CAP led stops blinking and the wln led lights up constantly and then release the button. But netinstall doesn’t find it still. Maybe somebody has an idea? Maybe I am doing the button part wrong?
Did you just try a reset to default configuration ?
https://wiki.mikrotik.com/wiki/Manual:Reset#Reset_from_RouterOS
