With each configuration. With every restart, my config is gone.
Is there a solution here?
What kind of config did you apply? Maybe you used Safe Mode? Check if the device has no physical damage or water damage, some short can cause the Reset pin to be activated.
When i change a SSID name and reboot the mAp Lite the config is gone.
The mAp Lite is not damaged i have the device now one day.
If you don’t reboot it. How long does it work for? Does it continue to work, if you close the configuration interface? Why did you reboot it?
Possibly all day but it’s about a mAplite want to use it at other locations as well.
The Config and the SSID everything is working but a restart is everything gone.(In safemode or not)
It could indicate a problem to write to Flash chip. While running, the config is in RAM.
Try to Netinstall the device. It could repair any Flash chip errors
I have done a firmware upgrade to v6.39rc80 problem is happily fixed
