mAP lite
http://routerboard.com/RBmAPL-2nD
What a beauty! Looks like this is best designed MT router for me. It doesn’t have a USB host? In that form-factor it can be really useful.
Seems like original mAP-2n will be upgraded soon to dual-chain mAP-2nD too. Maybe this time with not-passive PoE too? :slight_smile:
UPD: yeah, in the Quick Guide written USB “for powering only”. Still a good AP, with true-PoE.
nice device, very good price
Truly very nice.
Ordered two
Great piece of art. Beatutiful design.
Where do you ordered?
it is very attractive
price $20-25
num of chains 2
real af poe
but i want all three, not the usual “you can only have two of them” story.
this is actually what cAP should have been.
passive PoE is cheaper to implement no need for expensive injectors and or switches, that’s why mikrotik uses passive PoE to make devices and implementation more affordable.
I ordered it here
http://www.ip-sa.com.pl/lite-mapl-p-2047.html
Delivery planned for tomorrow :wink:
will be interesting to see a photo of the inside of that device
It’s always better when device supports 802.11af too. If you don’t have PoE infrastructure – add splitters and use passive PoE, but if you already have – it’s “Plug and Play”.
inside from FCC
I Got it. It’s so tiny. Great product !!!
Photos? Tests? Screenshots? :slight_smile:
Good idea to make it usb powered. So if there is no poe a powerbank can keep it running.
Or directly from a usb port from a smart tv/pc. No more PSU/AC plugs! :mrgreen:
I just put my hands on this device and it is very nice. Still figuring out the range of use of it, it is to be considered as “mobile” wireless device rather than a fixed one, although it will serve as a fix AP very well.
Anyway, my problem is with its default configuration. In a device which has only one ethernet interface, prohibiting connection to that interface by default is … well how can I put it, dumb? :slight_smile: Even if it gets an IP from dhcp-client configuration you can not connect it using IP or mac. I managed to connect to it using tik-app from my android phone and disabling the rule in filters which drops connection on ether1. I guess that even reset it will always bring the default configuration, only other way is to netinstall.
Now if you’re planing to give it to end users, this is going to be a real pain, unless of course you do the configuration for yourself and hope that the end user does not reset it, or … I am dumb myself and don’t know how to use the default configuration :slight_smile:
By default, you are only able to access the router through wireless interface as it is stated in the quick guide. The logic behind that is the ethernet goes to wall (ISP) and users are connected to wireless.
Fair enough, but you have to consider that a lot of people still use ethernet for configuration. While wireless devices are at hand of almost every one, it is not easy to configure a router using tik-app which is still in development. You have not implemented such thing for SXT for example. I know SXT is supposed to connect to internet through wireless and ethernet to the end user, but still it is so much more handy to configure through ethernet, in my opinion.
Anyone knows which are the serial ports?
Do you have any in System - Ports? If not, what exactly are you looking for?
