Hey all,
A bit about my setup. I have a Meraki MX 64 that goes into a cisco catalyst switch that goes up to a meraki ms220-8fp. Port 5 is the only port that is open for VLAN 2. Off of that comes the Routerboard mAP. Setting the switch port to trunk, native 2 allow all AND setting it to access vlan 2 both yield the same result - the mAP does not get DHCP from vlan 2. I am sure the vlan is set up with a proper DHCP pool so I am at a bit of a loss as to what I am doing wrong with the mAP. I am using winbox to configure and am not 100% sure what I need to do to have this all work together. Any help would be appreciated
