Dear Mikrotik users,
I bought a hAP AC2, a mAP and a mAP Lite to play around with. I gave them all mostly similar config. The hAP AC2 and the mAP Lite are working perfect.
The mAP gives a strange unstable WiFi issue however. Compared to the mAP Lite, the WiFI LED blinks on/off about once per second. The mAP Lite blinks more like an activity LED on a switch interface or like the HDD LED that your old desktop computers had. When connected from my laptop to the mAP, the WiFi connection stays up (also according to the logs in the mAP), but pinging the bridge interface that the WiFi interface is connected to gives very intermittent results. I get a couple of succesful pings, then a couple of failed ones, in no particular pattern. Pinging through the mAP to 8.8.8.8 gives the same result. When I connect a cable and try again, the device is stable and rock solid. It’s rather unsuspected as I try the same tests between my three different devices and only the mAP gives this behavior. All of the gear is running Routeros 7.3.1. Can someone give me some pointers to resolve this?
# jul/06/2022 17:52:21 by RouterOS 7.3.1
# software id = AGI6-DX5K
# model = RBmAP2nD
# serial number = HCD07X2YWVH
add name=bridge1 protocol-mode=none vlan-filtering=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add authentication-types=wpa2-psk mode=dynamic-keys name=wpa2 supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX default-forwarding=no disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge name=wlan2.4 security-profile=wpa2 ssid=map \
wireless-protocol=802.11
add name=lan-pool ranges=192.168.255.100-192.168.255.199
add address-pool=lan-pool interface=bridge1 name=lan-dhcp
add bridge=bridge1 comment=defconf interface=ether2
add bridge=bridge1 comment=defconf interface=wlan2.4
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment=defconf interface=bridge1 list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.255.254/24 interface=bridge1 network=192.168.255.0
/ip dhcp-client
add address=192.168.255.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=192.168.255.254
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip ssh
set forwarding-enabled=both
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=map
/tool mac-server
/tool mac-server mac-winbox
