mAP or mAP lite as cable tester
just a crazy idea - would it be possible to use mAP or mAP lite as an occasiona-use network cable tester?
https://wiki.mikrotik.com/wiki/Manual:Interface/Ethernet#Detect_Cable_Problems
But, as often with MT documentation, I can’t quite make whether this feature is implemented on mAP or mAP lite as well…
Well, if anyone has a good (and cheap) suggestion of a dedicated hardware, I’m eager to know. I think the only requirement is to detect wrong wires and the length at where the loop is opened.
