Manually setting TX power has been a mess for a while. The most reliable way I’ve found is to use the antenna gain setting to make the device think you have a stronger antenna so it reduces TX power proportionally for regulatory domain compliance.
I’m using Ubiquiti’s WiFiman to monitor the signal strength and one thing I noticed is the calculated distance increases as the antenna gain setting is increased. You wouldn’t happen to know whether this would have an impact on the devices that connect, in the sense that they may use more power to attempt to compensate for what they think is an antenna at a greater distance?
