MapLite Lost wireless Interface in winbox
Hello
Brand new HapLite
Cant seem to ger it back. It got Lost in a reboot with the reset Button.
I have tried to reboot in many ways using Button.
Can someone assist?
The “reset” button is not a reboot button.
Yes some others were confused, as there is no reboot or power on/off switch, and did reset the configuration to default.
Depending how long you pressed the reset button, you have the device is “some” state. (See “Reset button” in https://help.mikrotik.com/docs/display/UM/hAP+lite )
Power it on (plug in USB cable) without pressing any button, it might still come back with the default configuration.
With default configuration the ether1 port cannot be used to start configuration (WAN port, firewall protected)
