Hi all ;
today i will start a new topic related with the NAT document in the mikrotik web site .
i took the following part from it to start this topic .
Example of 1:1 mapping
If you want to link Public IP subnet 11.11.11.0/24 to local one 2.2.2.0/24, you should use destination address translation and source address translation features with action=netmap./ip firewall nat add chain=dstnat dst-address=11.11.11.1-11.11.11.254
action=netmap to-addresses=2.2.2.1-2.2.2.254/ip firewall nat add chain=srcnat src-address=2.2.2.1-2.2.2.254
action=netmap to-addresses=11.11.11.1-11.11.11.254
to start the topic with the simplest question then to make it more complex later .
assume i have the following ip’s from ISP :
192.168.1.1/24 for the lan
and my local network will have the following ip’s :
192.168.3.1/24
if i made mapping as the document say .
How can i activate the web-proxy and cache ? , then i will need to put a rule to redirect to port like 3128 in firewall NAT .
this is part one .
waiting your feedbacks and reply .
with best regards .
