Mapping static local IP to external dynamic IP
I need help mapping a fixed IP address to an external dynamic IP address.
I’m trying:
  • Access Synology NAS from Samsung TV via internet connection
  • The TV is on a local network and can only connect to a fixed IP address
  • The NAS is on an external network, that has dynamic IP with dyndns configured.
  • I’m using MicroTik RB750GR3 hEX router
How can I?
  • Configure the router, so that the TV can access the NAS using a static local IP like 192.168.1.99?
  • Any other method or suggestion is appreciated.
HI,
If you have a Mikrotiks on both sides easiest way is to configure EoIP tunnel.
If there is no other solution, then I will use microtik routers for both networks.
Both networks have dynamic IP with dyndns, that won’t be a problem?
I just have tested it on one side ( latest rOs RC ) and it saves fqdn in remote address field. You should be good to go.
