I want to change a little the data of Winbox window.
Can you make editable name of the board? With almost 7 or 10 chars?
It can be:
default value: RBname or
editable value.
xxxxxxxxxxxxxxxxxxxxxxxxxx on “RB450G”
Thanks,
It can be:
editable value.
Thanks,
/system identity
is the meny you are looking for
value name in 4.x?
/system identity set name="custom routeros name here"
in winbox this will be seen as:
user@host (custm routeros name here) - WinBox v4.1 on RB540G (mipsbe)
LOL,
I know this.
I need to change user@host Identity - WinBox v4.1 on MY_CUSTOM_NAME (mipsbe)
Thanks,
can’t do that
no, I know.. I’m making a request..
It’s possible that you consider this in a near future?
Why?
you can already promote your company, and there is no reason to hide the RB name and manufacturer.
I want to hide the RB name or X86, etc.
I have to make integrated equipment for one costumer that needs to avoid showing all the info about the hardware and labels. I have to take off my labels, all cases labels, and all the things I can hide using winbox. This is the literal reference to the board name..
you can use the API to make a special configuration application with your branding and only the features you need. this will also make sure he doesn’t do anything he is not supposed to do
hi normis,
can you put some more light on this??.. it will help me start working on to something… ![]()
I was talking about this: http://wiki.mikrotik.com/wiki/Manual:API
