in PCC script in Mikrotik wiki or PBR script .. You have to mark the connection in both direction (Inbound - Outbound)
to make the reply goes back into the same WAN interface it left from
Do i really need to mark the inbound traffic ??
is that what routing table do to make sure the traffic goes into the same interface generated the request
So i could just put in mangle section → mark outbound traffic (generated from LAN) then mark routing based on that connection mark
and Create a routing table for the WAN interfaces with the routing mark accordingly
Actually I’m curious to know whether it is critically important to mark the inbound traffic in multi wan environment or not necessary
When you have a good internet provider, it is really required because they will just drop the traffic when the source address does not match your connection.
When you have a lousy internet provider, they will accept the traffic. And they are the facilitator of a lot of abuse on the internet, so they should be prepared to be disconnected when the sh*t finally hits the fan and countermeasures are implemented.
It already happened for open mail relays years ago, so do not count on that it is never going to happen.
And finally mark-routing lines for the two ISP1_conn and ISP2_conn
if I remove the (Inbound) rules and just leave the outbound traffic marking along with the routing mark section. Will that cause issues in my internet connection.
I don’t use remote login to the router or any port forwarding services. It’s a simple public open wifi for hotspot internet connection in a small area.
Well technically that means it will not affect the internet surfing at the end the traffic will go back to the same WAN interface the request came from
unless for specific purpose you wanna keep the path from where you wanna access the router remotely (Specify which wan to use) or by pinging the router from outside .. right ?
you can imaging how it will reduce the code in mangle section and in turn reduce cpu working when having 10 WAN links !!
that’s the reason behind the question
