Marvell 98DX3255 unidir mirror
I have a Marvell 98DX3255 in a Mikrotik CCR2116-12G-4S+ and I was very disapointed to see that the mirror just works in one direction.
From what I read, this device which is btw one of the most expensive from Mikrotik should support mirror of both directions.
I have 2 other cheap Mikrotik devices and they work fine.
Does anyone face same issue?
Thank you in advance.
BR,
João
Check 7.15beta release notes:
*) switch - added support for multiple ingress and egress port mirroring on 98DXxxxx switches
So it’s coming.
Be advised not to use beta versions if this is a production device where you can not afford downtime.
