masquerade bug?
Hi there,
I just setup a RB711GA-5HnD to be an Access point with rOS 5.24, on the Ether side it have a public ip address and on the wlan side i have a pppoe server using radius auth, i also have wds enabled, because i have 2 mini cells conected to this AP and i need them bridged on the ether1 network. ok its all set up, the cpe is auth via pppoe and its connected, but no masquerade.. the masquerade doesnt work at all, my conntrack its enabled and everything the same as the other AP.. So with that config, i downgraded to the 5.22 and it start working like a swiss watch… i take a suppout and send it to support but i cant believe im the only one with this scenario.
Regards
JB
Update.
I have 10.2.102.0/24 as the pppoe pool, i just added the 10.2.102.253 to the AP and 10.2.102.2 to my laptop (whitch its connected with a sextant on station bridge) and the masquerade seems to work, so the problem its with the pppoe and masquerade.
What is your exact masquerade rule?
