Masquerade NAT appears to do nothing
Trying to make a basic router setup to get started - no default config, no vpns, eth 2-5 bridged, assigned local IPs in the 10.1.0.10-254 range, eth1 on wan, and I want eth 2-5 to be able to connect to the internet.
Client device is getting assigned a desirable IP (10.1.0.254 on the local network) and can ping the router at 10.1.0.0; however, client cannot ping any public IP.
As an example, router can ping 9.9.9.9 just fine, client cannot. Router can get DNS records, sync NTP, etc., client can't do any of that. Router is also getting blasted with script kiddies trying to brute force passwords...as expected.
(I'm sure the last 3 firewall rules are redundant, I put them there intending to use them for logging purposes. ipv6 firewall rules are just there for the script kiddies, I will deal with that later.)
When the client pings a public IP, there are no rules matched in the forward chain, however Torch is able to record that it happened - so clearly the router is seeing something, but if the firewall isn't dropping it, and the NAT logic is in place, how can I use logging to identify what is in fact missing here?
Full firewall config below:
# RouterOS 7.23.1
# model = RB750Gr3
add name=bridge1
add comment=intranet name=lan
add comment=internet name=wan
add name=dhcp_pool1 ranges=10.1.0.10-10.1.0.254
add address-pool=dhcp_pool1 interface=bridge1 name=dhcp1
/ip smb
set enabled=no
set discover-interface-list=lan
add interface=bridge1 list=lan
add interface=ether1 list=wan
add address=10.1.0.0/24 interface=bridge1 network=10.1.0.0
/ip dhcp-client
add interface=ether1 name=client1 use-peer-dns=no use-peer-ntp=no
add address=10.1.0.0/24 dns-server=10.1.0.0 gateway=10.1.0.0
set allow-remote-requests=yes servers=9.9.9.9
/ip dns static
add address=10.1.0.0 name=router.lan type=A
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=drop chain=input in-interface-list=!lan
add action=accept chain=forward connection-state=\
    established,related,untracked log=yes
add action=drop chain=forward connection-state=invalid log=yes
add action=accept chain=forward connection-nat-state=dstnat
add action=drop chain=forward connection-nat-state=!dstnat connection-state=\
    new in-interface-list=wan log=yes
add action=accept chain=forward log=yes
add action=masquerade chain=srcnat ipsec-policy=out,none log=yes log-prefix=\
    masqystuff out-interface-list=wan
/ip ssh
set host-key-type=ed25519 strong-crypto=yes
/ipv6 firewall filter
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.org
/tool mac-server
set allowed-interface-list=lan
/tool mac-server mac-winbox
Using address 10.1.0.0 - with 0 et the end - as bridge, gateway and so on is a bad decision as the same value is the network mask. Try to change it to eg. 10.1.0.1 for test.
The first and last address of the pool should not be used as they are assumed to be network address and the broadcast address respectively.
... or check here:
https://www.calculator.net/ip-subnet-calculator.html?cclass=any&csubnet=24&cip=10.1.0.0&ctype=ipv4&x=Calculate
Column 1 Column 2
IP Address: 10.1.0.0
Network Address: 10.1.0.0
Usable Host IP Range: 10.1.0.1 - 10.1.0.254
Broadcast Address: 10.1.0.255
Total Number of Hosts: 256
Number of Usable Hosts: 254
Subnet Mask: 255.255.255.0
Wildcard Mask: 0.0.0.255
Binary Subnet Mask: 11111111.11111111.11111111.00000000
IP Class: C
CIDR Notation: /24
IP Type: Private
Not just the address in error!
but also dhcp server network
Should be:
add address=10.1.0.1/24 interface=bridge1 network=10.1.0.0
add address=10.1.0.0/24 dns-server=10.1.0.1 gateway=10.1.0.**1
Would have been clear on defaults :wink:
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
Also title is presumptuous and unfairly targets the innocent: "the masquerade".
Perhaps
Beginner Setup Not working - What did I do wrong?
.. and possibly also draw blood from the innocent?
:grimacing:
https://en.wikipedia.org/wiki/File:Vampmasq.jpg
I assumed 10.1.0.0/24 and 10.1.0.1/24 would be the same here, as I misunderstood the config as [subnet mask] rather than the reality of [bridge IP]/[netmask].
I also assumed by "hosts can't use this address" it somehow excluded the router itself :person_facepalming:
Will test it, thanks.
They aren't the same, one bit of a difference makes them distinct. And it does say address=10.1.0.x/24 ... not mask or network or anything else.
In CIDR notation they represent the same subnet (since the first 24 bytes are the same), and this looks like CIDR notation for a subnet mask, so I got confused :slight_smile:
