I am trying to enable RTSP streaming but I am getting errors in the logs.
dstnat: in:ether1 out:(unknown 0), connection-state:new src-mac 00:ff:ff:ff:ff:fd, proto TCP (SYN), MYPCIPWAN:57138->MIKROTIKROUTERWANIP:554, len 60
192.168.0.2 is the server that has the open ports specifically port 554 RTSP
thank you for looking ![]()
Firewall rules are
/ip firewall address-list
add address=WANIPREMOVED comment="Intranet Server" list=AllowRemoteIPS
add address=DNSIPREMOVED comment="Allow House Dyndns " list=AllowRemoteIPS
add address=VPNSERVERREMOVED comment="VPN Server" list=AllowRemoteIPS
add address=MYOFFICEIPREMOVED comment="Corporate TEMP IP FOR REMOVE IN CASE HOUSE FAILED REMOVE" list=AllowRemoteIPS
add action=accept chain=forward connection-nat-state=dstnat in-interface=ether1
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat connection-state=established,related,new
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add chain=input comment="Remote Management Policys" dst-port=8291 protocol=tcp src-address-list=AllowRemoteIPS
add chain=input connection-state=established
add action=accept chain=input connection-state="" dst-port=554 protocol=tcp src-address-list=AllowRemoteIPS
add action=accept chain=input dst-port=554 protocol=udp src-address-list=AllowRemoteIPS
add action=accept chain=input dst-port=80 protocol=tcp src-address-list=AllowRemoteIPS
add action=accept chain=input protocol=icmp src-address-list=AllowRemoteIPS
add action=drop chain=input protocol=icmp
add action=drop chain=input in-interface=ether1
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=3389
add action=dst-nat chain=dstnat comment="Hikvision Ports" dst-port=443 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=443
add action=dst-nat chain=dstnat dst-port=8000 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=8000
add action=dst-nat chain=dstnat dst-port=8001 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=8001
add action=dst-nat chain=dstnat dst-port=80 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=80
add action=dst-nat chain=dstnat dst-port=83 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=83
add action=dst-nat chain=dstnat dst-port=1935 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=1935
add action=dst-nat chain=dstnat dst-port=7661 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7661
add action=dst-nat chain=dstnat dst-port=559 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=559
add action=dst-nat chain=dstnat dst-port=554 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=554
add action=dst-nat chain=dstnat dst-port=554 in-interface=ether1 log=yes protocol=udp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=554
add action=dst-nat chain=dstnat dst-port=16000-16005 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=16000-16005
add action=dst-nat chain=dstnat dst-port=7668 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7668
add action=dst-nat chain=dstnat dst-port=7662 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7662
add action=dst-nat chain=dstnat dst-port=6204 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=6204
add action=dst-nat chain=dstnat dst-port=6203 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=6203
add action=dst-nat chain=dstnat dst-port=6111 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=6111
add action=dst-nat chain=dstnat dst-port=6011 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=6011
add action=dst-nat chain=dstnat dst-port=8686 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=8686
add action=dst-nat chain=dstnat dst-port=10015 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=10015
add action=dst-nat chain=dstnat dst-port=8877 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=8877
add action=dst-nat chain=dstnat dst-port=7666 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7666
add action=dst-nat chain=dstnat dst-port=8555 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=8555
add action=dst-nat chain=dstnat dst-port=7660 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7660
add action=dst-nat chain=dstnat dst-port=7334 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7334
add action=dst-nat chain=dstnat dst-port=7332 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=7332
add action=dst-nat chain=dstnat dst-port=15443 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=15443
add action=dst-nat chain=dstnat dst-port=15310 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=15310
add action=dst-nat chain=dstnat dst-port=15300 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=15300
add action=dst-nat chain=dstnat dst-port=18001-18020 in-interface=ether1 log=yes protocol=tcp src-address-list=AllowRemoteIPS to-addresses=192.168.0.2 to-ports=18001-18020
