I’m quite new to RouterOS and wanted to use RB2011UAS-2HnD-IN to replace my WRT54GL.
The possibilities with RouterOS are amazing but currently I’m struggling with some strange issue.
Current setup
Relevant ports:
ether10 - Uplink to the WAN, currently using DHCP Client for this.
IP 10.2.0.197/16
Gateway 10.2.255.254
vif1 - Virtual Interface for Metarouter mr1
bridged to net-local
net-local - Bridge for combining (future) virtual interfaces
IP 10.0.255.254/16
DHCP-Server to serve 10.0.0.1-10.0.255.253
ether10 on the routerboard is configured to use src-nat masquerading on outgoing packets to hide the routerboard routes from the 10.2/16
Metarouter:
mr1 - Openwrt on the latest working trunk revision
Memory: 24 MiB
Static Interface vif1 (internaly available as eth0)
Within the Metarouter:
I’m trying to use Tayga to run a NAT64 for experimenting with it
eth0 inet addr:10.0.0.1 Bcast:10.0.255.255 Mask:255.255.0.0
inet6 addr: fdc3::2/64 Scope:Global
inet6 addr: fe80::f8:8ff:fe9d:76e9/64 Scope:Link
tayga-nat64
inet addr:10.0.0.1 P-t-P:10.0.0.1 Mask:255.255.255.255
inet6 addr: fdc3::2/128 Scope:Global
Tayga uses some tunnel device and maps fd64::/96 to 10.64.0.0/16 addresses.
The metarouter got src-nat masquerading enabled to map these 10.64.0.0/16 to its 10.0.0.1
Problem:
From within the metarouter i can ping 10.2.0.1 (some device available behind routerboards ether10) and see these icmp packets arriving at 10.2.0.1 from 10.2.0197 as expected. So for me it looks like they are passing both masquerading rules and are translated two times.
The strange thing is, when pinging fd64::10.2.0.1 from within the metarouter I’m also able to receive the icmp packets on 10.2.0.1 but they are sent from 10.0.0.1. So they aren’t handled in the routerboards ether10 outgoing masquerading rule.
The only difference for this packets I could see is that they are passing the metarouters tunnelling device.
But from the scope of the routerboard I expect them to be passed through vif1, routed to ether10 and masqueraded there.
I know this is quite unusual setup but I’m happy for every hint you can provide. Especially I’m interested if there is some special treatment for tunnelling devices on metarouters.
Kind regards
Phil
