Mass upgrade loses wireless interface!!!!!
Hello guys,
Recently i updated from dude server 4 to 6.43.11 with success in a RB750gr3 chr.
When try to upgrade mipsbe devices in my network to 6.43.12 (about 15 devices,all routers) the process is completed with success and routers are rebooted, but wireless interface is lost in almost all of them!!!
I have all packages of the latest version into the server files directory including the extra packages.
When i upgrade manually (drag and drop with winbox) to the latest version, all is ok!!
Anybody have any idea why this happens through mass upgrade process??
I did i little search and found that this has happened before without mikrotik’s answer in the subject.
Do we have any update about that?
on those devices, go to System → Packages and check if the wireless package is enabled.
Up to version 6.34 they had 2 wireless packages that could be activated one at a time, wireless-cm2 and wireless-fp. My old R52Nm cards only worked with wireless-fp.
It got fixed in 6.36 and they removed wireless-fp, only wireless-cm2 left.
6.37 and above the package was renamed to just wireless.
BMena thanks for your suggestion, but the wireless package is not even there.
What i have noticed is that:
When i do the upgrade through Dude, the package disappears and i have no option Wirelles in the menu. When i do it drug and drop through winbox everything is ok, the package is there and i can adjust wireless setting and create new connections.
I will recheck it for sure and provide feedback.
