Master port and bridging issues
Hi ,
I am currently facing a problems with the master ports bridging issues short decription i am having two wan connection one from SFP port and the other from ethernet 1 , the issue will be my sfp wan is down and i want use the ethernet 1 to get the internet but it couldnt be connect unless my ethernet 1 is putting under same bridge with the other ethernet port hence i am having a doubt why my previous configuration on the sfp port as a master port (not in the same bridge) it still can get the internet connectivity in contrast why the ethernet 1 required to put under the same bridge , i will need to figure this out as i need to create an pcc load balancing which the ethernet 1 shouldnt be slave for the bridge.
Regards
LoiWJ
