I’m facing a problem that seems defect crash
electric, but has occurred three times in the last month which leaves me
concerned.
I wonder of you will agree that it is defective.
In a POP:
Nano → Ominitik (PA 5.
→ Groove (PA 2.4)
All ports in bridge, Groove stopped, clients fell, but Ominitik the Groove door was “R” in Neighbors Groove does not appear.
I changed “bridge” to “master port” back for a while and back
problem. Always turn off and on solve. -
A tower with 2011, 3 door “bridge” or “master port” even
problem. totally dismantled the bridge put a range for each
port returned to work. -
A client with 2011, 3 door (6,7,10) with the “master port” with
equipment below, I moved to bridge now resolved.
- AP Groove
- HAPLiteAC
- 2 Nanos (PTP) + 1 Groove.
As you can see in any case there is the possibility of real loop. But
I disabled the STP bridge and Nanos.
Whenever I leave the door alone reappears who is connected
the neighbors and works normally.
It’s happened to you?
