I am a newbie and experimenting with RouterOS in VMware.
In my config there are 2 hardware NICs and VMware’s NAT (+ I tried bridging with software lopback adapter) and they are visible in RouterOS, I managed to bridge traffic from WAN to LAN, but I can’ tune the internet on the local machine that runs RouterOS in VMware. I guess I have to bridge all the local NICs for that and the guide says I have to set one NIC as Master Port and other as slave ports wiki.mikrotik.com/wiki/Manual:Initial_Configuration#Setting_up_Wireless.
But the problem is that there is no such option ![]()
Should be like this:
Do I have to set up some options so that master port would appear or this is normal for virtual RouterOS?
If it is normal, then how can I set up RouterOS to make the internet appear on host PC running RouterOS in VMware?
Thanks in advance ![]()
