I’m having trouble implementing DiffServ over an MPLS network, since the Mangle rules don’t seem to examine packets that have an MPLS label and there doesn’t seem to be a way to force it to do so.
Test network is as follows:
Router1 - Router2 - Router3
Router1 mangles packets and sets DSCP to 46 (EF), with a 3 Mbps ingress policing. It’s the ingress edge of the MPLS network.
Router2 is MPLS core. It has queues implemented that on a non-MPLS network (re)classify and schedule traffic as follows:
[admin@Router2] /ip firewall> mangle print
0 ;;; Already marked packets are considered "trusted", so we'll honor their DSCPs and won't inspect them (which is faster)
chain=forward action=mark-packet new-packet-mark=ef passthrough=no dscp=46
[admin@Router2] /queue tree> print
5 ;;; Traffic to CanBonastre (video feed)
name="1.1-ef" parent=ether2 packet-mark=ef limit-at=3M queue=ef-pfifo
priority=1 max-limit=3M burst-limit=0 burst-threshold=0 burst-time=0s
6 name="1.2-af11" parent=ether2 packet-mark=af11 limit-at=0 queue=tcp-wred
priority=2 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
7 name="1.3-af12" parent=ether2 packet-mark=af12 limit-at=0 queue=tcp-wred
priority=3 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
8 name="1.4-af13" parent=ether2 packet-mark=af13 limit-at=0 queue=tcp-wred
priority=7 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
9 name="1.5-be" parent=ether2 packet-mark=no-mark,best-effort limit-at=0
queue=tcp-wred priority=8 max-limit=0 burst-limit=0 burst-threshold=0
burst-time=0s
Router3 is MPLS edge for egress.
The thing is, if MPLS is enabled in Router2 the ip mangle doesn’t match the DSCP value within the packet (and therefore sends it to the 1.5-be queue since the packet-mark is “no-mark”, instead of marking it with packet-mark “ef” and sending it to 1.1-ef queue.)
Is there any way to force the firewall mangle rule to examine and match the MPLS-tagged packet contents, so that it can then police it?
I’m aware of the other industry common implementation (using EXP bits to classify/police within MPLS), but I haven’t been able either to set up a filter to match MPLS EXP bits and then police the traffic with a queue tree. I’ve read this http://wiki.mikrotik.com/wiki/Manual:MPLS/EXP_bit_behaviour and tried to set up an IP Mangle rule (Matching Advanced > “Ingress Priority” and using Action “set priority”), and that doesn’t seem to work.
If I disable MPLS, then the DiffServ domain scheduling, policing and classification works OK. It’s just the Mangle/classifier that doesn’t work with MPLS tagged packets.
Any suggestions on how to do this? Is it just me or is this feature really not implemented?
Regards,
Aleix
