Hello.
I was trying to match IP address and MAC address in firewall but I have not been able to do it.
I just set up the following Gaps.
firewall / General / Chain forward
firewall / General / Src Address 192.168.200.21 (it is an example)
firewall / Advanced / MAC address 00:0E:41:52:A4:B8
but, when I set the last line, firewall reject packets from this machine.
Maybe this is not the way to match MAC address and IP address.
Please, I will appreciate any help from you.
Ivan Perino
sorry, the action is ACEPT
I have not shown the entire configuration but it has been working well since months.
The point is that I want to match (on firewall) by IP address and MAC address too.
I will tell you the problem.
Clients change theirs IP just for watching what happend. and a lot of IP DUPLICAATED messages appears in clients who have the same IP address.
I thought If I clould check which MAC belong to such IP addres I could deny access to this issues.
THANKs (sorry if my english is not so good as you could expect)
If somebody has a extension idea about same problem and it can take the modification from a common place (web, mikrotik, etc). Pls take it him/her ideas because I have a same problem.
I have a idea with ARP table. If I can modificate the ARP tale of Mikrotik by a script then is it a possible idea.
this script makes all dynamic ARP table entries static
for example, if you have a new user, it sets/receives via DHCP his new address, is being added to ARP table as dynamic record. then this script makes that record static. but when your old user changes its IP address, script will not add another static ARP entry with the same MAC
well, if you do not need control of ‘duplicate’ MAC addresses, at least in v3 you may use the following command to convert all dynamic entries to static:
:foreach i in [/ip arp find dynamic=yes] do={ /ip arp add copy-from=$i }
iwant one more support, please help me , in my network iam introducing radius manager with hotspot i would like hotspot login auto redirect for the desired pool only , but its working for all the hosts who are connected to my network
i dont want this and i dont want to use user bypass in hotspot menu
