MAX CPU/CORES suppor
Does MK support 2 CPU each with 6 cores on stand alone install, or only if KVM is user or another virtual machine?
Thank you.
dave
RouterOS supports that fine on a bare metal install. Make sure to use 5.x, it has a lot more multi-core support than older versions.
THANK YOU!
What do you think about KVM using on this kind of HW?
I have no opinion on that.
