10MHz channel support 40 Client max on 802.11, if all the users simultaneous want 512k and if all clients have 100/100% CCQ, and hardware-retries set to 7 on both CPE and AP.
On Nstreme the band is little lower (max 38 client @ 512k), but the connections are more stabile = no retransmissions
On NV2 I think you go up to 50 users @ 512k
5GHz-N:
Really there is no differencies from 5GHz-a, the 10MHz limit is valid for both protocol
but the N protocol can go up to 32.5Mbit if the chip support this channel width.
you can add ~10 users for all type of modulation, with this protocol:
802.11 max 52
Nsteme max 50
NV2 max 64 users.
some people say it is true that 10MHZ is more clear from interference and more stable , but ping spikes and latency can more occur with 10MHZ because of the width of 10MHZ is narrower , and oise of 10MHZ hits your signal at the same frequency , all the channel that will drop and latency spikes can occur.
is that true or the real origin of that problem could be because of overloading 10MHZ channel with lots of users so when all of them do download the latency and ping spikes occur?
there are two opinions that i dont know which one is right
is the latency , spikes because of
A- 10MHZ generallycould be more affected by noise ?
B- or it is because of overloading 10 MHZ with the bandwidth that it can’t withstand ( more than 30Mbps)
if it is because A , then w can’t do anything, but if it is because of B, we can prevent it by simply not overloading the 10MHZ channel with more than 25 or 30bps.
i want to know which one is right in order to take the right decision to swith to 10 MHZ or not
The right answer are B (in noise-less environment)
In perfect link 10MHz can carry max 20Mbit/s on non-NV2 setup
NV2 increase the download when are less upload from CPE
About the noise:
less MHz channel = less data and more signal strenght
more MHz channel = more data and less signal strength
more data for MHz (like the future 802.11ac) = more interferencies TO other operators & more interferencies FROM other opertors.
