Max number of interfaces in VRF table
we have issued situation that max number of interfaces we can put in one VRF table (or under one routing mark) is 30.
Is there any way to change this, or is there maybe some plan to change it in some future release?
Thanks in advance.
Radaleks
Hi
Did anyone answer this, or did you work out that this was really an issue for you? We seem to have encountered the same problem, which is just unbelievable
Brad
Use the CLI it works
