Hi ,
On RB1100 , how many PPPoE client can support ? And how many PPPoE server ?
thanks
brasileottanta
Hi ,
thanks
brasileottanta
It depends.
There’s no real answer to that question, it depends on what else the router is doing. QoS (how many queues? Queue tree or simple queue?), IP firewall rules, size of the routing table, IP accounting, whatever. The most important variable is packets per second on each PPPoE client connection.
Yep ,i know.
So , about 300/400 client and simple queue with radius auth.
bye
Right.
As stated the most important impact is pps through the router.
You’ll probably be fine, though. You can go to PCQ instead if you’re getting close on CPU utilization.
