Maximam Distance for Point to Point transperent Bridge
Dears ..
I have the following hardware :
2 RB433AH , 2 R52H and 2 antenna 20 dbi .
i have configure it as point to point transperent bridge .. can i know whats the maximam distance i can do it with this point to point link to geive best performance , lowest latency and maximam bandwidth transfer .
your urgent kind help is much appreciated .
Thanks and kind regards
What distance and speed do you actually need?
higher distance = lower speed.
fully extend your arms and measure the distance…that’s max. wireless link.
Max depends normaly for long ranges on the altitude ASL “above sea level” , also the signal should be in 60dbm-65dbm in both sides, and you will have a good speed, also use 5Ghz for long distances because of the smaller fresnel zone .
Greetings.
My dear ..
The Distance is 22 Km and i have 45 Mb full duplex , what i need to know is :
1- is the needs only 2 RB433AH , Antenna 20 dbi and R52H on the two nodes only or i need to put more repeaters in the line of sight ?
2- is using one RB433AH enough to carry 45 Mb full duplex or i have to share thi BW between tow or three devices ?
please note the twore hight is 70 M on the AP side and 35 M on the clinte side .
