I consider using CCR 1036 for centralized NAT at a (W)ISP. Does anybody have experience with the maximum number of connections the CCR can handle simultaneously and any ideas if this can be monitored with SNMP?
I can easily get approx 900 MBit through with NAT, so I’m more concerned with the number of connections.
The maximum concurrent number of active NAT connection, for any devices, are 32767 (ports range 32768…65535 [0x8000 to 0xFFFF]) for each public IP used.
Thanks. I guess it might be a question of memory and CPU used for keeping track of all connections. An ASA 5510 with base license is limited to 50k connections, but that seems to be a limitations based on license level.
Anyone with real-life experiance of CCR’s NAT capabilities and performance?
