Maximum Size of Xen Image?
hi,
Does anyone know what the maximum size image I can create to run within my MT router? After creting images of various size, 2GB, 3GB and 4GB it seems that only the 2GB copies across properly, as soon as you go over that size there is a problem. Now I am also not sure if I am doing anything wrong, I have MT on a 256MB compact flash card and an 80GB HDD as my store.
Any ideas would be greatly appreciate!
i have done tests with 10 and 20 GB images without problems. There are no software limitations imposed for XEN image, only limiting factor is your hardware.
