Maximum Storage?... and, DHCP Server Default on routerboar?
How large of a compact flash card can you use with a Mikrotik Routerboard?
I see some of the vendors selling them with 64 and 128 mb flash cars, but never seen anything sold above 128. Just wondering if the board doesnt accept anything larger than that or if there is really no sense in using anything larger than that because you would never use it.
Also, when you setup a new RB532, does it default to being a DHCP Server?
Because, I have a d-link router hooked to the cable modem that acts as a dhcp server.
Then, I have my RB532 Ether1 hooked to port 3 of the dlink. periodically, I have to unplug the d-link to reset it because the internet isnt connected. Finally, I just assigned all my devices an IP because the Obtain an IP automatically wasnt working out. It seemed to clear the problem up.
You can use 16Gb if you want. It works very well, for proxy cache for example.
Thanks, I was kinda wondering if I would be able to use the Gb flash cards.
