maximum virtual/slave wireless interfaces?
It seems like there’s a limit of 2 virtual wireless interfaces per physical interface. I tested on both radios on my hap ac2, and on my map lite, with same results. Is this just a limitation in RouterOS v7.8?
I’m aware of the performance loss issues with several SSID’s. But the idea is to have multiple SSID’s ready to enable/disable when needed, and never have more than 2 active at a time.
Howcome the third virtual wifi interface doesn’t become slave, even if I disable the first or second one?
