MB with 6 PCI slots
Hello
can someone recommend a motherboard that has 6 PCI slots that works with ros?
:slight_smile:
use search :slight_smile:
http://forum.mikrotik.com/t/upgrade-from-beta-to-final-when-released-question/1858/1
http://forum.mikrotik.com/t/anyone-used-a-gateworks-with-mt/5690/1
Opps! I should have known better, Thanks :slight_smile: :slight_smile:
I have a question about PCI 2 MiniPCI adapter with 4/8 minipci slots.
Can one PCI slot deliver enough power to 4/8 miniPCI cm9 cards?
I saw people use this but Im a little afraid that it can be a problem sometimes.
we did a test with 4 such (8 port) cards in one PC and it worked ok
What about IRQ-s, did every card got its own IRQ, have you tested bandwidth with that setup?
Please, is anyone using this in a real environment with success. What about IRQ’s what about bandwidth with these pci to minipci adaptors?
http://forum.mikrotik.com/t/pc-freezing-info-from-ros/29841/1
That does not answer my question. I dont plan putting sr5 or any high power cards. I plan putting r52 cards. Cm9 cards. I asked about IRQs and possibille power issues.
