Hello ,
in the MC7304 I can only use channel 2 for data\info
so if the modem is running I can’t check the signal.
I can see I have 9 channels - but no matter which channel I give - it doesn’t give data
is there any way to fix this ?
Thanks ,
Hello ,
Thanks ,
I’ve got the same modem and with PPP connection there is no way without disabling internet 1st.
it is ppp serial Firmware limitation of modem.
