MC7304 won't connect to 4G (LTE)
hello,
I’m having some issue with the MC7304/7354
becasue I can’t see which network I’m connected (because using data\info channel = 2)
I have setup the modem using at command “AT!selrat=06 (LTE)”
but it doesn’t connect
when I ask my ISP they say it try to dial using wrong user name…
when I use the same user name with another modem MC8790 MC7710 its work on 4G
does any one know\ have the same problem ?
it is a firmaware issue ? I’m using “9999999_9902674_SWI9X15C_05.05.58.00_00_GENEU-4G_005.026_000-field”
how can I know which user the modem is “sending” ?
Thanks,
