Dear forum:
I haven’t found on 3.0 version manual the meaning of Tx/Rx Rate on wireless interfaces.
I can see this only on RouterOS to RouterOS links.
In my case, it says 48Mbps/2/36Mbps/2 and I would like to know the interpretation of “/2”.
I realy appreciate any clue from you, thanks a lot
Ivan
if you use turbo mode you can see 482/482 because of use og 40Mhz channel.
I think that if this is /2 you are using 10 MHz Channels. It is possible?
Regards,
Martín.
That’s right man. Thank you a lot. I sould have guess it!.
I am working on 10MHz.
