MED parameter not applied in a BGP VPN L3 with eBGP for PE-CE communication
Hi, we have set up a MPLS VPN L3 network to connect two datacenters for customers private traffic as described in attached diagram and all looks like is working fine but BGP attributes to manage MPLS iBGP preferred routes learned in PEs.
We installed a couple of routers in each location for redundancy in case of failure. We would like to define one of the PEs in each side of our interconnect (PE1 and PE3) as main by controlling the active iBGP learned route in each one. As we have Set up eBGP to connect PE-CE routers we defined SoO filters in PEs VRF definition (It works great to avoid loops) and eBGP rules in CEs to set up MED parameter. When disabling MPLS and not use VRF like a pure BGP routed network on this same scenario, we could see that MED attribute works fine, but when moving to MPLS VPN L3 MED attribute appears in iBGP learned routes in the remote PEs, but does not take effect. ¿Do you know any way to make it work according to our needings? I know that this works in Cisco routers and I think that we’re missing something or I don’t know if this is not possible under Mikrotik environment, but we’re very interested in these type of devices.
Hola José, veo que estás familiarizado con Cisco, te comparto unos artículos que escribió uno de nuestros Arquitectos de Red Senior
Cisco to MikroTik – command translation – BGP
https://stubarea51.net/2015/11/09/cisco-to-mikrotik-command-translation-bgp/
Cisco to MikroTik – command translation – OSPF
https://stubarea51.net/2018/01/05/cisco-to-mikrotik-command-translation-ospf/
Cisco to MikroTik – MPLS
https://stubarea51.net/2018/05/03/cisco-to-mikrotik-mpls/
Con nuestros clientes utilizamos otro tipo de acercamiento para lograr alta disponibilidad, combinando MPLS, BGP, OSPF y algo de TE (Traffic Engineering) para definir las rutas, dependiendo del caso específico.
Otro punto que me gustaría compartirte es que utilizamos EVE-NG para nuestros laboratorios, te lo recomiendo para que puedas jugar con las configuraciones sin afectar el ambiente de producción.
Espero que te llamen la atención los artículos y que te sean útiles.
Saludos!
Un millón de gracias por los enlaces compartidos, son muy útiles y los tendremos como referencia rápida para solucionar bastantes problemas vía consola en vez de tener que abrir Winbox. En relación al post, ya resolvimos el problema vía filtros BGP. Un saludo.
