Medisana Smart Baby Monitor IP-Camera behind the MikroTik RB2011UAS-2HnD-IN
Hi, All!
I need your help, because I have got stucked trying to eliminate my issue with port forwarding. :confused:
Here is my situation description briefly: Medisana Smart Baby Monitor IP-camera (hereinafter - Medisana) is connected to router MikroTik RB2011UAS-2HnD-IN (hereinafter - Mikrotik) which is connected to ISP (Internet) via Ethernet1 port.
ISP gives me dynamic public IP-address. So, it changes from time to time after reconnection.
Mikrotik configuration
RouterOS: 6.28.
ISP plugged into Ethernet1 port (by default).
Router has the default configuration:
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address=192.168.88.1/24 comment="default configuration" \
    interface=ether2-master-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid \
    interface=ether1-gateway
add address=192.168.88.0/24 comment="default configuration" \
    gateway=192.168.88.1 netmask=24
/ip dns static
add address=192.168.88.1 name=router
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=pppoe-out1
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related
add action=drop chain=input comment="default configuration" \
    in-interface=ether1-gateway
add chain=forward comment="default configuration" \
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
    connection-nat-state=!dstnat connection-state=new \
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=pppoe-out1 type=external
I made the following adjustments:
set allow-remote-requests=yes servers=77.88.8.88,77.88.8.2
add action=dst-nat chain=dstnat comment="Medisana SMB IP-camera" \
    dst-port=222 in-interface=ether1-gateway protocol=tcp \
    to-addresses=192.168.88.222 to-ports=222
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
set [ find default-name=sfp1 ] disabled=yes
Mikrotik is reachable via the Internet from anywhere (i.e.: public IP x.xx.xx.xx). :sunglasses:
Medisana configuration
IP: 192.168.88.222
Mask: 255.255.255.0
Port: 222
Gateway: 192.168.88.1 (Mikrotik)
DNS: 192.168.88.1 (Mikrotik)
Connected method: UTP-cable or Wi-Fi (it does not matter).
IP-camera is reachable only from LAN, unfortunately. When I try to get it from public IP-address of Mikrotik (i.e.: x.xx.xx.xx:222) – no response and no forwarding for 222 port.
Question: what is wrong and what should I do to see a picture from my IP-camera? :open_mouth:
Thank you in advance for technical assistance!
How are you getting your WAN public IP? by DHCP or dialing pppoe?? your settings seems to have mixed setups.
Dialing PPPoE (on Mikrotik).
Then you should delete
/ip dhcp-client
And change all ocurrences of ether1-gateway with pppoe-out1, which is the β€œreal” WAN interface.
P.S. Enable IP > Cloud for remote access to your medisana by name instead of the dynamic IP.
pukkita, thank you very much for reply. I will try it and post here the results. :slight_smile:
Hello!
Here is the solution for my problem! :smiley:
The problem was mostly in time synchronization NTP (System=>NTP Client) and one mistake in NAT rule (IP=>Firewall=>NAT - see screenshot attached).
See my config alterations:
add action=dst-nat chain=dstnat comment="Medisana SMB IP-camera" dst-port=222 \
   in-interface=pppoe-out1 protocol=tcp to-addresses=192.168.88.222 \
    to-ports=222
Pay your attention here: in-interface=pppoe-out1
/system ntp client
set enabled=yes primary-ntp=91.226.136.138 secondary-ntp=109.195.19.73
/system ntp server
set enabled=yes
Despite I set current time manually it was necessary to configure NTP Client.
Thanks to pukkita for the tip!
