why change the design on your rb411 afaik without notification ? now it doesnt fit inside my antennas anymore so I have to get some new spacers…
takes alot longer to assemble the equipment now… not too happy
what was changed ?
the minipci slot is slightly higher than on previous models. so the rb411 with wireless card doesnt fit in Mikropoint antennas anymore unless you get new spacers…
This new design arrived when you got the 411U card.. The U card is about 1cm longer too, so its abit odd to change the design of the normal 411 as it doesnt have the minipci slot for 3g modem and is 1 cm shorter
