Mejor opcion de MIKROTIK para 3000 abonados
Voy a instalar internet en 2 ciudades, la una de aproximadamente 500 abonados y la otra de 2500 abonados (a futuro).
  • Cual es la mejor opción y que equipos MIKROTIK serían los recomendados para esa cantidad de usuarios?
  • Se puede utilizar el thundercache ?
    Les adjunto la imagen de las opciones que creo podrían ser. Gracias por la ayuda.
Warning. This is English only forum. Please rewrite your post in English.
What if the user hardly speaks English?
I usually see some posts here in Russian and nobody complains.
A. What if forum moderators hardly speak Spanish? Should we accept post in eg. Katakana or Hindi or Hebrew alphabets?
B. Moderators do “complain” about non English posts.
C. If English is not your “best friend” then you can always use translator or write/ask on non English forum.
D. This forum has some rules to obey.
Bad posts can be reported by other users.
That could be a worse option.
The point is not to avoid English gratuitously.
We accept other language only on case the other the English translation is in the post simultaneously. This is just only English forum. If someone cannot speak English enough, he would be welcomed on any other mikrotik related forum that accepts his language. Unfortunately he will not be able to set his router anyway.
Please help us to keep this forum clean and readable for everyone.
+1
Sent from Tapatalk
in this Facebook Group you can find Help in spanish
en este Grupo de Facebook puedes encontrar ayuda en Español
https://www.facebook.com/groups/WIRELESSTIGRE/
